JDM H22A Type S with ATTS on OBD1
Hi guys, first post here. I've got a 94 Accord coupe Obd1, and have a H22A Type S engine in it. So the engine has ATTS, after reading on the forums for a while I've learned that ATTS will not function at all when it isn't used with its proper ECU. So having ATTS in my car but not working, does that have any effect on how the LSD works? Will it cause any damage to anything? Also is there any way to get it to work using my Obd1 ECU? Thanks.
Duplicate thread closed. If you wish to respond to this thread/OP please respond in the other thread linked below:
https://honda-tech.com/forums/engine...-obd1-3348150/
