1991 civic wagon alternator removal HELP
Old May 11, 2020 | 05:07 PM
Nino Ouk's Avatar
Default 1991 civic wagon alternator removal HELP
I can’t get the alternator out from the bottom of the car I thought I’d just post this before I take my brake master off...
Old May 11, 2020 | 05:47 PM
Marcos Barrios's Avatar
Default Re: 1991 civic wagon alternator removal HELP
do you have it hitting both the back of the block and rear crossmember?
Old May 11, 2020 | 05:49 PM
Nino Ouk's Avatar
Yeah, should I get it From more of a side angle?
Old May 11, 2020 | 08:00 PM
Tyson's Avatar
Is the bottom bracket off?
Point the pulley facing upwards and it slides right out the wheel well.
Also helps to disconnect the shock and let the knuckle sag. Necessary if you have shortened race shocks, probably not.
Old May 15, 2020 | 06:38 AM
prboy1969's Avatar
A pry bar, a piece of wood, a long metal pipe, or a long screw driver. Then just pry the engine on a solid point. 9 out of 10 times it will move enough to slide it out without having to remove the Master Cylinder. Also, helps to have someone to pull on the leverage bar. That way you have both hands free to finagle the alternator.
Old May 15, 2020 | 10:40 AM
CV19hoax's Avatar
Is the wagon that much worse than a CRX/ hatchback? I know the engine bay is smaller but I got my CRX one through the top
Old May 15, 2020 | 01:18 PM
Tyson's Avatar
still trying to remove it??
i prefer the actual designed/intended way to remove things (thru the wheel well), but theres two other ways, one being by removing the brake MC temporarily, the other is by removing the air intake tube and shuffling it over the crossmember and out.
these are desperate solutions, like trying to fill the tranny oil thru the VSS. half-assed, but works if primary method isnt available/possible.
don-ohio
Sep 12, 2003 03:46 PM
