96 prelude si h23a swap
Look up coolant hose routing for a Prelude VTEC of your year. The P14 will be good enough to start it and check for leaks but that's about it. You will not have any VTEC, low rev limit, etc.
So you have a non-vtec H23A then? Sorry, typically when people say "H23A" they are referring to the JDM H23A VTEC blue top engine.
If yours is not VTEC then the P14 will run it fine. You would just look up coolant hose routing for a 92-96 Prelude Si w/ H23A1 engine instead.
