Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
R18 theoretical ECU swap
Old May 10, 2020 | 05:01 AM
jimmy63's Avatar
Icon5 R18 theoretical ECU swap
Fellas,
cant find much info on this, so it might be a stupid question.
As some of you may know the AU ECU's for most of the 8th gen civics are bitches and not supported by tuning solutions.
I have a FN1, and was wondering the if its possible to swap out the ECU + wiring harness if needed for another 8th gen ECU that is programmable?
In this case im thinking a FN2/FD2 ECU because we have plenty them over here and then re-flash/calibrate the ECU to perform for a R18a2 engine?
Is something like this possible? im new to this and dont really know what you are capable of when reflashing an ECU. I know the Type R ECU is made for a k20z engine but does reflashing/calibrating allow the ECU to be sort of reprogrammed for another 8th gen engine?
I know its most likely not worth it because the r18 engines are such a bitch to work around. Also, you are probably better off doing an engine swap or just straight up buy a type r and slap a turbo on it but a man can dream of making this his sleeper.
Cheers,
paulandsab
Honda CR-V & Element
Mar 21, 2020 04:51 AM
alcidespn
May 15, 2018 06:27 PM
EFz6er
Jun 9, 2014 02:26 AM
cwritten
Apr 29, 2011 06:30 AM
