Need Help with a 98 Accord
Old May 9, 2020 | 09:48 AM
Cassiemm's Avatar
Default Need Help with a 98 Accord
Hi I need some help with my 98 accord. For some reason it randomly starts acting up while I知 driving. The speedometer and tachometer will start jumping around then just stop working, then my radio with start cutting out, and then the car will stop accelerating and eventually it just dies. It値l start right back up if I jump start it, I replaced the alternator about 6 months ago, put new battery terminals on it, I知 not quite sure what else to do.
Old May 9, 2020 | 10:54 AM
99stockcivic's Avatar
Default Re: Need Help with a 98 Accord
If you scan the car do you get any computer codes back?
If nothing, my guess is perhaps the ignition coil is bad.
Or...maybe the Ignition Control Module.
Old May 9, 2020 | 02:07 PM
2001GSRSC's Avatar
5 Year Member
So many systems effected. Look for a common point in the wiring diagrams to start. Cables replaced, meaning that some harnesses were bad, and the system was disturbed. I would look at the main relay.
The altnerator is spinning , and producing, but there is something in the way of the current.
Old May 13, 2020 | 01:01 PM
Antigravity Batteries's Avatar
Have you tested the battery?
Old May 13, 2020 | 05:59 PM
I know it's not something I would want to hear, but it is possible the alternator is bad again. I'm not sure why there are so many **** manufacturers of alternators for these older hondas, but it seems like most auto parts store alternators are garbage. Had a case last year where I had to replace the alternator three times until I found a good one that has lasted.
Cassiemm
May 5, 2020 03:27 PM
manchester8
Nov 28, 2006 06:05 PM
cecknight
May 30, 2003 06:38 AM
