2000 Honda accord transmission problem
Old May 4, 2020 | 01:54 AM
Carlos Moore's Avatar
Default 2000 Honda accord transmission problem
I recently bought a 2000 Honda accord with 276k I miles as a project picked it up cheap. Was told it probably needs a new transmission it goes into reverse and drive but it takes a few seconds to engage and jerks between those gears makes a clicking noise when going in reverse. Doesn't seem to shift if I'm correct a few seconds after accelerating the d4 light blinks. I think the code was p1768 I can't remember I did test the solenoid the one on top with 2 motors and the 2 below it. Now the top solenoid works when I applied 12v to both sides when it came to the ohm resistance it was off I read it should be between 17 to 25 if its not within spec it's bad. I haven't tested the liner solenoid which is the one with 2 separate connections but it's one piece. I'm just second guessing myself now lol because I almost have the old transmission almost out the car 🤦‍♂️. I still wanna test that part it because I found a low mileage tranny on Ebay a jdm imported from Japan they said I would have to swap all of the sensors over for it to work and I don't wanna put bad solenoids on a good tranny and still have problems has anything experienced these symptoms I know this is alot explaining lol just trying to explain much information as possible thanks.
Old May 4, 2020 | 05:27 AM
99stockcivic's Avatar
Default Re: 2000 Honda accord transmission problem
I'd probably go to the junkyard and get a set solenoids there. Or buy them off ebay.
I'd do the same as you, throw the other transmission in there. Your sensors are unlikely to be the problem unless broken. Just move those sensor over to the JDM tranny. Then put on a "new" set of solenoids.
Old May 4, 2020 | 10:33 AM
What would be a good quality set of solenoids to buy . I know Honda are pretty expensive probably just go that way save up a little but I will check the prices on them. One one solenoid was out of ohm range but it still worked when I applied 12v to it.
Old May 5, 2020 | 07:26 AM
Ebay is a decent place to start:
https://www.ebay.com/itm/OEM-Shift-C...1bef23e0a1cce9
$50 approx for the solenoids.Of course, double check these match yours.
Old May 5, 2020 | 07:51 AM
roddrick's Avatar
Premium Member
5 Year Member
replacing the solenoid's at the mileage that you have on the car may not help. if the transmission has not been serviced properly. I would suggest trying to drain and refill the transmission(x2) to see if it helps before buying solenoids or a new transmission.
put the car on jack stands or a lift and run it thru the gears with the new fluid each time. then the last try and drive it around and see if it helps
Old May 5, 2020 | 07:59 AM
Not suggesting he put new solenoids on old transmission. Put them on the new transmission instead of moving the old ones to the new tranny.
If you still want to play with the old transmission, then try all the usual. Swap solenoids, change the fluid multiple times, clean out the old solenoids, check fluid level. If that doesn't improve, and you already have another transmissions, just swap them and use the new solenoids you bought.
Old May 7, 2020 | 12:54 PM
I'm just gonna replace the transmission so I won't waste money buying Honda fluid which is not cheap. I was advised to swap old solenoids to the transmission I'm purchasing because it's a Japanese import for the swap to work correctly. Definitely buying new fluid for the replacement transmission there is 1 solenoid that I might have to replace because it's not within ohm specs which is the lockup solenoid
Which I have attach with a picture
HawaiiHonda
Mar 9, 2012 11:04 AM
Javaair
Sep 2, 2010 09:41 AM
Nocturnal
Jul 25, 2006 03:43 PM
JSV4.0
Feb 1, 2005 06:56 PM
