Stock gsr rods capacity(n/a) I know this has been done
Old May 1, 2020 | 11:37 PM
purposebuilt's Avatar
Default Stock gsr rods capacity(n/a) I know this has been done
Hi have look at alot of post about this but most are turbo builds and 10+ years old . So I'm in the mild of building a mild all motor gsr with nippon jdm itr pistons and stock rods with arp 9mm rod bolts and was woundering how much hp tq they can hold. So I know what I have to tune the car to. It's my weekend fun car. So would 220be do able. I heread on the turbo post 350whp but dont know what that equates to in n/a power. Thats
Old May 2, 2020 | 09:55 PM
JKaze's Avatar
10 Year Member
Default Re: Stock gsr rods capacity(n/a) I know this has been done
I’m not sure did you wrote those last sentences seriously, but kW or ”hp” is what it is, no matter how you are feeding air to the engine. Anyway, it is little stupid way to rate components by output power. Think about it. You can reach some specified level of power with very different conditions because it is sum of work and time. In piston engine case, cylinder pressure and rotational speed. Boosted engines for example, can reach higher power level in lower revolutions than naturally aspirited, which is simply result of higher cylinder peak pressures. That is directly increasing oscilating stress of rod and piston. I highly recommend studying bacis of physics and four stroke otto-engines.
But those P72 rods are fine for naturally aspirated engine when talking about strength, only ”disadvantages” are weight and press fit piston pin.
Old May 4, 2020 | 02:27 AM
Thanks kinda makes me feel stupid but guess its the only way I learn . But has any one have similar set ups with no problems
Old May 4, 2020 | 06:12 PM
KiNGDEE206's Avatar
Well let’s put it this way I’m not sure just speculating also
a stock gsr turbo bone stock just arp head studs they safely go up to 350whp/250tq ish
so that gives you idea how strong they are up to 8500rpm your using arp rod bolts so it’s safe proven up to 9000rpm
na. You can probably make up to 220whp (depending on dyno/ head /cams / ported or not/ bla bla)
with 135-145tq ish na
thetes plenty of B20vtec basic builds that is solid. Here’s one I’m copying to give u idea power you can make
ofc yours gsr so minus 10-15hp with 10-15tq
https://www.tamparacing.com/forums/v...eap-build.html
but every dump read different. Don’t get stuck on numbers
the 1/4 and driver mod is what matters
Old May 7, 2020 | 03:37 PM
Thanks for your input but I'll just go with eagle rods
Old May 8, 2020 | 05:29 AM
Chance EG's Avatar
You're going with forged Eagle rods... for your mild NA GSR build?...
Ok then.
Old May 8, 2020 | 06:45 AM
TheShodan's Avatar
Moderator
Ok then.
it's ok.. There's nothing wrong with a little extra safety. especially of the stock rods weren't shot peened and balanced.
Lsweez
Feb 26, 2007 07:28 PM
Mr HYDE
59
Mar 18, 2004 09:35 AM
JunIntegra
10
Nov 8, 2003 06:06 AM
