Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Intermittent No-start. Starter Spins
Old Apr 29, 2020 | 03:20 PM
John66's Avatar
5 Year Member
Default Intermittent No-start. Starter Spins
So, I've had this problem on my 07 Civic LX for a while. I have an intermittent no-start. The starter spins but doesn't engage. Battery's good. I've replaced the starter with a reman and it still does it. I've also replaced the starter relay. Since it spins, it seems like a solenoid problem, but I replaced the whole starter. I guess there's a better than zero chance I replaced a bum starter with another bum starter. I didn't buy top of the line, but even so that seems unlikely right out of the box. Any thoughts?
Old Apr 30, 2020 | 12:05 PM
hondamark35's Avatar
Default Re: Intermittent No-start. Starter Spins
check the teeth on the flywheel for damage. probably the best way to do that is to remove the starter and rotating the engine by hand while checking through the starter opening until you're all the way around.
another way to check is to roll the car forward, in gear when you have the no-start condition to move to a different (potentially less damaged) area of the flywheel. if this works, there's a good change that's your problem
Old May 5, 2020 | 07:50 AM
John66's Avatar
5 Year Member
Thanks for the reply. So, my question there would be, would a flywheel issue produce a complete non-engagement with the starter's gear? I'm not having rough starts or grinding noise. It's pretty much all or nothing. You can turn the key several times and hear nothing but the whir of the starter spinning and then the next turn of the key it starts right up.
Old May 5, 2020 | 08:02 AM
GIZZ - EXV's Avatar
Loved
Make sure your main power wire contact is clean and tight. If that's okay chances are you have a bad reman starter. I work at the dealer, for whatever reason maybe 1/4 of the times if we use a reman jobber part due to time or $$$, that non-honda starter will fail.
mugen94
Aug 9, 2009 03:16 PM
M1SCO15
Feb 19, 2008 04:51 PM
Touge Tuning
May 3, 2006 11:14 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
