Swap honda ef 1991
Hello everyone!
i have a honda ef 1991, with swap d16a9, my question is, what wiring should i use inside the engine compartment and inside the car to work everything correct?
keep the wiring thats in there now
you keep the factory wiring
you just have to modify a few things to make it work with your new engine
never go out and buy a new wiring harness never
was your car automatic before?
if yes then the reason your back up lights dont work is because you didnt connect the switch for the reverse lights
its the two wires on the manual trans
não é isso amigo. Preciso da fiação que fica embaixo do painel e da que fica no motor do carro. Eu comprei o carro sem fios, apenas teve a troca de motor, agora eu preciso a completa fiação
ok then what you need is to find the wiring at the junkyard
thats the only real option
are you in brazil?
because if you are
then your not going to find the wiring haha
in brazil people use the cars until theres nothing left
are you in brazil?
because if you are
[QUOTE = Marcos Barrios; 52169559] ok então o que você precisa é encontrar a fiação no ferro-velho, essa
é a única opção real
no Brasil?
porque se você é
então você não vai encontrar o haha fiação
no Brasil as pessoas usam os carros até que não há nada esquerda [/ QUOTE]
I am from Portugal do you know what wiring I have to buy?
no Brasil?
porque se você é
yes you need to buy the wiring thats for your car for the 1991 civic or the 1990 civic inside the car and under the hood
and i dont know how people treat cars in Portugal so maybe youll get lucky down at the junk yards
just try to find a harness thats not all cut up
