Need help identifying a plug
Old Apr 28, 2020 | 09:55 AM
Manuel Campos's Avatar
Default Need help identifying a plug
I need some help identifying a plug next to ecu 00 civic hatch dx
Old Apr 28, 2020 | 08:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need help identifying a plug
'96-00 Manual Civics have three plugs connected to the ECU. In the '96-98 Civics, all three plugs are connected to the engine harness. In the '99-00 Civics, two of the three plugs are connected to the engine harness and the remaining one is part of the dash harness.
From your vague photo, I am going to bet that you have a '96-98 engine harness set into your '00 Civic chassis. Another indicator would be to examine the green crossover plug. Do all wires on the engine harness side of this plug meet corresponding wires on the chassis side ? I suspect not. If you wish for your wiring to be painless, you need to start with a '99-00 engine harness.
Last edited by JRCivic1; Apr 29, 2020 at 09:06 PM. Reason: Emphasis on the solution.
Old Apr 29, 2020 | 09:08 AM
Well I'm having a hard time trying to start the car but the main relay dont buzz and the fuel pump wont turn on I bought a new main relay and put in a new fuel pump new distributor I cleaned the ground to the thermostat
Old Apr 29, 2020 | 07:48 PM
Jordan Wilson's Avatar
You need a 99-00 engine harness...
Old Apr 29, 2020 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I think I said that.
Old Apr 29, 2020 | 09:04 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You did but OP didn't seem to get it, the repeat might be helpful.
Old Apr 29, 2020 | 09:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It won't start and the fuel pump will not prime because you have the wrong engine harness. Again, you need a '99-00 Civic engine harness.
Old Apr 29, 2020 | 09:18 PM
my bad you did!😏
Old Apr 30, 2020 | 11:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
my bad you did!😏
No worries... now let's see what the OP does.
Old May 6, 2020 | 06:57 AM
the car was running when they parked it a few years ago
Old May 6, 2020 | 07:09 AM
tony_2018's Avatar
Fish Twig
For **** sake, more details on the car....and why is that plug not in the ecu? Its needed.
mrbsponge
Apr 18, 2006 04:11 AM
hatchback_al
Nov 27, 2004 09:31 PM
