Key stuck, also stuck in park
My mom's 2013 civic key won't turn all the way back to the rear position, and can't be removed unless you disconnect the battery. The "p" indicator dosnt light up, but all the other gear lights on the dash do. The shifter is stuck in park, and will only shift if bypassed with the overide button. Checked all fuses. Brake lights work. Car starts fine and can drive. Pulled out the plastics around the shifter, the shift lock solenoid isn't getting any power. Checked microswitch at the park location on the shifter, and it has continuity. I feel like the car thinks it's not in park, where else do I go to check? Any idea where I can find a wire diagram? Thanks
mistersink
Honda Fit
13
Jul 14, 2014 11:18 PM
bowerskd
Oct 2, 2008 02:47 PM
zachgk7
Mar 12, 2007 07:07 AM
