Deatschwerks DW400 installation
Old Apr 25, 2020 | 10:07 PM
MitchSchaft's Avatar
Default Deatschwerks DW400 installation
I ordered the DW400 and an Airtex sock. I found out there is no way to install the sock because it doesn't fit the hole. Deatschwerks told me to use the green sock that came with it. What would you do?
I keep reading how you need to use the OEM style sock. If I can use the green sock then I will need to lob the bottom of the hanger off so it will fit.
96 Accord LX f22b2
IHE, catless 2.25", f23 intake, delta 272, aeromotive fpr, dsm blacktops. Boost project.
Old Apr 26, 2020 | 04:47 PM
Default Re: Deatschwerks DW400 installation
I think I'll have to take the chance and remove the base of the hanger and just run the green sock that came with it. I only know of what other guy running this pump and that's what he had to do in his '98 civic.
credit: Jacob Scherrman '98 Civic
Old Feb 17, 2021 | 08:46 PM
Farzan Dean's Avatar
Hey does removing the base, and using the green sock work? Wondering if I should do that with my 98 civic?
Old Feb 17, 2021 | 09:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The only issue you will likely run into using the green sock pictured in a 5G/6G Civic is that it may start sucking air at lower fuel levels in the tank... being that it won't fit flatter in the tank. I have had one for months that needs to be installed into my Supercharged Civic... looks like I need to figure out a solution for what you have asked here. I didn't know the stock style sock wouldn't fit. Thanks for sharing.
Old Nov 29, 2023 | 06:50 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Anybody figure this out yet? Looking to buy a DW400 pump as well for a 1992 civic and there’s no info on it online, and when I called DW today nobody picked up after multiple attempts…
jamisont327
Audio / Security / Video
Aug 10, 2017 05:39 AM
demian22
Nov 6, 2007 07:52 AM
PhantomX
Mar 11, 2006 07:22 PM
asianalbutt
Nov 18, 2005 06:29 PM
ProjectMurder
Dec 12, 2002 09:19 PM
