Shodan's catch can setup on a LS motor...Questions
Old Apr 20, 2020 | 06:53 PM
Stopsign32v's Avatar
Loved
Default Shodan's catch can setup on a LS motor...Questions
So I plan to keep the catch can setup on my motor simple. No valve cover bungs and I'm still up in the air about a drain back or not.
Then plan is a basic catch can mounted high as possible on the firewall.
Then I was going to run it as a "drain back" but have the block plugged and the hose from the bottom of the catch can to the bottom of the frame and have it capped. Theory was when I changed the oil I would drain the can.
With that being said I got to looking back at Shodan's setup here https://honda-tech.com/forums/forced...vents-3335314/ and it seems this might be a better option.
Goals:
  • Vent the block enough to keep the motor happy
  • Have no milkshake sludge get into the oil pan from condensation (big deal to me)
My questions are with the one way check valve, that still has to let it be an open system so that means condensation will still get into the can making it a milkshake, correct? Other than having to check your oil level more often, is there a point in draining it back into the block? Plus with the one way check valve it should limit the amount of oil in the can period, correct?
Old Apr 21, 2020 | 12:13 PM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Shodan's catch can setup on a LS motor...Questions
You are under the impression condensation only happens in a catch can? Just drain the oil back
https://shop.boostinperformance.com/...t1-gtr-aos.htm
look at this “catch can” theres a lot of thought put into this and guess where the oil drains... the motors its designed for also make about 4 times the power you are probably aiming for
Old Apr 21, 2020 | 07:24 PM
TheShodan's Avatar
Moderator
Goals:
the check valve's purpose is to keep crankcase pressure and ventilation going in One Direction, not to control the amount of oil that goes into the actual can.
as long as that check valve is pointing in the correct direction as shown in the sticky, there should not be any milkshake style issues. When using a quality oil, the amount of condensation that drains back into the crankcase will have little effect to the dilution of oil that is within the system. Again, that's if you're using a very zinc content quality oil.
Old Apr 21, 2020 | 09:36 PM
Loved
I strictly use Rotella T6
Old Apr 22, 2020 | 06:14 AM
TheShodan's Avatar
Moderator
That should suffice. 15w-40?
Old Apr 22, 2020 | 07:46 AM
Loved
5W-40
Old Apr 22, 2020 | 11:36 AM
TheShodan's Avatar
Moderator
5W-40
hmm. I need to recheck the zinc content in that weight. The Rotella tends to run a little thin on turbo components on that weight..
Old Apr 22, 2020 | 12:28 PM
Loved
That's what I run now. So you're suggesting 15W-40 when the turbo goes on?
Old Apr 22, 2020 | 05:05 PM
TheShodan's Avatar
Moderator
I'm suggesting to check for something a bit more robust. I'll be checking my resources.
Old Apr 25, 2020 | 02:23 AM
turboem1b18c5's Avatar
How about Mobile 1 synthetic, I been reading it's pretty good compared to the Rotella, and has decent zinc content.
Old Apr 25, 2020 | 07:31 PM
TheShodan's Avatar
Moderator
No..Not even close. I'd never use that oil ever again. try the Valvoline VR1
Old Apr 25, 2020 | 08:09 PM
I'll give that a try on my next oil change. Running the Shell T6 currently. Thanks for the recommendation.
Old Apr 25, 2020 | 08:23 PM
Loved
I'm going to stick to Rotella until I see proof there is another that is better and can be bought at a local store.
Old Apr 25, 2020 | 08:46 PM
What is the cost to have oil analysis by Blackstone labs I think it's called. That would be helpful to really know what is going on, I don't think it's too costly.
Old Apr 26, 2020 | 05:50 AM
TheShodan's Avatar
Moderator
thats used for oil issues, not sending purchased oil.
Stopsign32v: you're not going to find high ZDDP content oils in stores anymore due to new oil regulations for vehicle use. The only othees iv've used with success are Castrol GTX SYNTH and Pennzoil platinum SYNTH.
Old Apr 26, 2020 | 09:01 AM
Txdragon's Avatar
Valvoline VR-1?
Old Apr 26, 2020 | 01:30 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I just add a bottle of zync to each oil change
Old Apr 26, 2020 | 03:13 PM
Loved
I've read that isn't a good idea.
Old Apr 26, 2020 | 05:22 PM
TheShodan's Avatar
Moderator
Originally Posted by Txdragon
Valvoline VR-1?
Perfectly fine to use and highly recommended...Stopsgn32v wanted "off the shelf" brands. Valvoline VR-1 has always been special order, and not just sitting in Walmart shelves
Old Apr 26, 2020 | 05:36 PM
Txdragon's Avatar
They have it at O'Reilly's and Advance Auto in my area. Depending on his location, they may not sell it. We have no emissions testing or anything out my way.
Old Apr 26, 2020 | 06:11 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
year 2 and every part in my motor looks brand new still. I had my Pro1 cams out last week
https://www.walmart.com/ip/Rislone-3...xoC-_4QAvD_BwE
Old Apr 26, 2020 | 06:14 PM
DaX's Avatar
DaX
Loved
Community Favorite
I couldn't find VR1 synthetic on the shelf. I think I did see VR1 conventional though. I just order a case of 6 (VR1 synthetic) through Amazon. Buy 6, use 4, then there are 2 more quarts on your shelf in case you need to top off.
Old Apr 26, 2020 | 10:47 PM
Oh I see, thanks for the clarification. Learn something new everyday.
Old Apr 27, 2020 | 12:39 PM
TheShodan's Avatar
Moderator
That's how most of us get it
Old Apr 27, 2020 | 03:12 PM
NVturbo's Avatar
O.G. triple O.G.
Agreed on the Mobil 1. I recently did an oil change using that and the engine sounds a bit off, not as healthy and smooth like before. Will definitely go back to using Pennzoil Full Synthetic. Hell, it's cheaper too.
