Rev limit kicks in early
Old Nov 15, 2002 | 12:24 PM
Hondasaurs's Avatar
Default Rev limit kicks in early
Here is my problem: I have a PG7 ECU (89 Integra). The ECU redlines at 7600 rpm. Recently the revlimiter has been kicking in between 6500-7000 rpm. I replaced the cap and rotor, plugs and wires. Any ideas what could cause this?
Old Nov 16, 2002 | 09:07 AM
jlicrx's Avatar
Default Re: Rev limit kicks in early (ZC_CRX)
is this when the motor is cold? pg7 has a cold revlimiter which i think is usually at 6200.
Old Nov 16, 2002 | 09:08 AM
Kamin's Avatar
Default Re: Rev limit kicks in early (jlicrx)
and CEL?
Old Nov 17, 2002 | 10:00 PM
Koori's Avatar
Ouch, if that's the case.. Hitting the limiter on a cold engine, SMART!
Old Nov 17, 2002 | 10:42 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Rev limit kicks in early (Hadji)
if the CEL is on it'll limit at ilke 6500
Old Nov 18, 2002 | 04:32 AM
Hondasaurs's Avatar
Default Re: Rev limit kicks in early (dLo GSR)
I found the problem. My tach signal wire was almost cut in half from a T-Tap that I used form my auto-meter tach. I redid the connections and it is fine now.
JasonST
Jan 17, 2007 05:44 PM
JasonST
Jan 7, 2007 07:17 AM
JasonST
Aug 29, 2006 03:02 PM
JasonST
Aug 24, 2006 05:08 PM
Hondasaurs
Nov 15, 2002 01:46 PM
