94 civic
Old Apr 19, 2020 | 04:22 PM
Like100stickmen's Avatar
Default 94 civic
I have a 94 Civic ex that cranks but doesn’t start, it has no spark but it is getting fuel and I don’t know where to go, I replaced almost everything in the distributor to the wires and I just have no idea, I need help please
Old Apr 19, 2020 | 04:25 PM
99stockcivic's Avatar
Default Re: 94 civic
First....this is the accord forum, you probably should put this in the Civic forum.
But, okay, maybe someone will move it there.
You say you tested the spark, how? Did you test the wires or made sure voltage is getting to the distributor? You could have a dead distributor, or maybe a coil in the distributor, or maybe a loose wire from the distributor.
How do you know it's getting fuel?
Old Apr 19, 2020 | 05:34 PM
I thought this was the civic forum so my bad, but I used a spark plug tester and it didn’t light up on all of them, I disconnected the fuel line, primed it and it shot into the bottle I had, and everything I the distributor has been replaced
Old Apr 20, 2020 | 06:38 AM
My hope is it is the distributor coil. Otherwise it's the distributor. Coil is easy to swap in. But I would also check to make sure you have voltage to the distributor before you buy the coil. You can usually return the coil at most shops if it doesn't work.
Keifgerm
Nov 4, 2018 02:03 PM
Turbocivic94
Sep 25, 2008 11:13 AM
Bad Teggy
May 11, 2006 01:09 PM
CivicBoi
Jul 12, 2002 08:57 AM
