1999 civic no crank no start
Old Apr 17, 2020 | 05:05 AM
charleshsmith's Avatar
Default 1999 civic no crank no start
It will do a rolling start and has manual tranny. The clutch safety inter lock has been bypassed. With a key dash lights come on but there is no clicking noise when key is turned to start. What do I check next?
thanks,
charles
Old Apr 17, 2020 | 05:28 AM
K20.ek's Avatar
Default Re: 1999 civic no crank no start
Check your relay and fuse
Old May 5, 2020 | 03:49 AM
Okay, took the long way... Took starter out and it bench tested good. Squeezed the solenoid wire connector. Started fine. Took it to work and back home and wouldn’t start next day. Swapped to spare key because the one I was using was very worn. Now starts fine. I’m thinking the ignition switch is about to go.
Old May 5, 2020 | 07:46 AM
tony_2018's Avatar
Fish Twig
Might as well get some new keys. Don't make a new key with the old one, not worth it.
Old May 5, 2020 | 07:59 AM
GIZZ - EXV's Avatar
Loved
I would test the ignition switch next
Old May 14, 2020 | 08:20 AM
I replaced ignition switch and key lock. Seemed to work as it had recently - intermittently. Replaced main relay And no change in intermittent starting. If I turn key with no start then rock the key from start to almost on position eventually the starter will get power. Wondering if it is the starter solenoid even with good bench test on starter...
Old May 14, 2020 | 08:50 AM
Audripulls's Avatar
The grommet on your clutch pedal positions switch might be missing.
Old May 14, 2020 | 09:37 AM
I have the clutch safety interlock bypassed.
Old May 19, 2020 | 05:58 AM
I recorded this video of the current starting process. After the previously described work I have to rock the key between start and on to get it to crank. Starter solenoid?
tanked_honda
Honda Civic (2001 - 2005)
Nov 2, 2019 03:00 PM
B20VtecVillain
Mar 27, 2016 10:47 PM
d1slide
Mar 18, 2016 10:48 AM
fivecrew123
May 29, 2013 02:00 AM
iixerOii
Aug 14, 2005 08:01 PM
