P28 or P30 ecu for DC2R
Old Apr 16, 2020 | 07:21 PM
mr_munro's Avatar
Default P28 or P30 ecu for DC2R
Hi All
Need an ECU that I will socket ready for a tuning platform.
Which is better, out of the 2 for a dc2r Australian version ? I read that p28 disabled knock sensor which would obviously not be ideal?
Old Apr 16, 2020 | 10:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: P28 or P30 ecu for DC2R
The knock sensor in an OBD-1 ECU is essentially to save the engine from ignorant owners who put substandard fuels into their tanks. The engines get too noisy above 5000 rpm, so the knock sensor turns off above that. So the P30 will only help you if you put 87 octane in your Type R. Otherwise, the circuit pathways inside the two ECU's are identical. Each can do (and will perform) the same with any tuning solution.
CRX_RR
Feb 21, 2008 04:20 PM
streetracerof06
10
Dec 29, 2005 06:14 PM
systemoverload
Dec 11, 2005 10:09 AM
SETI20
Aug 17, 2004 11:57 AM
turbotime
Jun 8, 2003 09:15 AM
