Front passenger side wobble
Bent rim
bad/bent upper or lower control arm or bushing
bent/bad axle
worn out/bad tie rod
bad ball joint
bad bearings maybe
You should be able to get under it and move things around to find the loose, broken, missing, bent, or worn item on that side.
Jack up car and move the wheel around to see if you can get the play while still
bent/bad axle
bad ball joint
bad bearings maybe
