Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Spark plug gap size
Old Apr 15, 2020 | 11:03 PM
joenobodyyet's Avatar
10 Year Member
Default Spark plug gap size
I have a 2008 Honda Civic LX 4 door automatic transmission with 98,000 miles. I picked up 4 NGK IZFR6K-11S 5266 Laser Iridium Spark Plugs. I bought them from RockAuto.com since they seemed to have the cheapest price with shipping. I also saw some super cheap ones on Ebay, but I don't want to risk them being fake (fingers crossed mine aren't fake ha). Anyway, I picked up some feeler gauges today (the one with the bent metal blades, NOT the coin style) and these spark plugs all seem to be pre gapped around .040. At what size should they be gapped for my car? I read .043, and some give a range. I've watched youtube videos showing that there should be a little drag when you slide the gauge in, but I'm trying to be careful to not break the iridium tip. Any tips and help is appreciated, thanks!
Old Apr 18, 2020 | 08:40 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Spark plug gap size
To be honest, I just usually throw them in and run it. I was told current plugs are usually pre-gapped to the application they are for. Even if that's not 100% accurate, .040 to .043 isn't much difference and I believe the car will still run on the .040 just fine. Over time the gap will widen anyway with wear and for awhile it will be ideal at the .043 until it's starts to go even wider. Even then the car will run fine for some time before needing to be changed out.
I too don't like gapping the tiny tip iridium plugs due to breakage and expense of the plugs.
Originally Posted by 8thCivic.com forum
NBPRudy
Premium Member
Joined Apr 28, 2006
64,413 Posts#7 Jun 18, 2008
the CSX-S K20Z3 OEM gap is 1.0-1.1mm (0.039-0.043 in.)
If that helps any!
02civicsi
Registered
Joined Jan 28, 2007
28,322 Posts#8 Jun 18, 2008
Don't touch the Iridium tip on the plugs & they come pre-gapped from the factory.
projected3
Oct 2, 2010 09:50 AM
ZenDynasty
Jul 8, 2005 11:07 AM
nyo91
Jun 24, 2004 05:06 PM
PearlWhiteAccord
Jan 15, 2004 10:43 AM
Dels98R
Dec 9, 2002 06:10 PM
