89 JDM B16A swap in a 97 EK Civic
Old Apr 15, 2020 | 02:10 PM
Wolfeman2001's Avatar
Default 89 JDM B16A swap in a 97 EK Civic
So I have a 89 JDM B16a that iv been swapping into 97 ex civic for a while now. Everything has been hooking up fine so far until I got to the electrical part. I know that the motor came originally obd0 and my car is obd2a. So I switched the intake manifold, injectors, throttle body, and distributor all to 99-00si. I also have changed my alternator to a 96-00 obd2 and have a 99-00si Vtec pressure switch/solenoid coming in the mail. Sadly I never had a wire harness due to previous from the previous owner taking it and I need help with figuring out what wire harness can fit my engine swap but still be used in my car. If someone could please help me figure out all this confusing electrical bullsh*t Id be grateful.
Old Apr 15, 2020 | 02:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 89 JDM B16A swap in a 97 EK Civic
This is what I posted to your query in the other thread... and thanks for making your own thread, as well as providing more specific information.
"You use the engine harness that came with your car... and if you don't have it, GET ONE just like the one that should have come in your car. Then, modify it to fit the new engine... lengthening or shortening wiring and changing plug types as necessary. You didn't feel it was necessary to provide ANY information about your chassis or the year/model "B" series swap, so I cannot be more specific."
This means you need a '97 Civic EX engine harness... and if you get an automatic harness (4 ECU plugs and the green crossover plug), you can use one of those extra wires for your Knock sensor.
Old Apr 15, 2020 | 02:32 PM
So what specific information do you need??
Your saying I should I go and get a d16y8 engine harness, that’s manual, and it will plug up to my 99-00si intake, dizzy, injectors, etc.? Or do I have to buy all the plugs and rewire them myself?
Old Apr 15, 2020 | 02:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by Wolfeman2001
So what specific information do you need?? You provided all of the information that is needed here, and I thanked you for that. You provided absolutely NOTHING in the other thread that you posted in when you said "What harness do I need for my "B" swap".
Yes, you will need a '96-98 Civic EX engine harness. A manual one will provide all of the necessary plugs that you will need to use on the B assuming you have all OBD-2 type parts (alternator, injectors, IAT, dizzy). You may have to lengthen or shorten some of these plugs, but no issues. You will have to run a single wire through the firewall for your knock sensor since you are using a '99-00 Civic Si ECU. You will also need an OBD-2A -> OBD2B ECU adapter harness so that you can plug your ECU right in.
If you get a '96-98 Civic EX automatic engine harness, you will have a bunch of extra plugs that are not needed in the engine bay, and you can convert one of these wires to the knock sensor and not have to run a lone wire through the firewall. You will also have to convert the 3-wire IACV to a 2-wire plug, but otherwise it will be pretty basic. You will still need the ECU adapter harness. Your call.
Old Apr 15, 2020 | 03:44 PM
Ok that’s good to know, so my motor is out of an 89 crx and used to be obd0 but I changed it to obd2b being (IM, throttle body, injectors, alternator, and dizzy) and I have a JDM p30 ecu and it’s obd1. Will that still still work on my car and motor, or do I have to run a 99si ecu?
Second, I thought I needed 99-00si engine harness to use obd2b parts not the obd2a engine harness.
My last question is because my motor is noe obd2b is there anything else I need to change so that everything is the same OBD?
Sorry if these are stupid questions, this engine swap and wiring is all new to me and I want to make sure I don’t miss any small details or have waste my money and time on unnecessary stuff.
Old Apr 15, 2020 | 04:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Ok that’s good to know, so my motor is out of an 89 crx and used to be obd0 but I changed it to obd2b being (IM, throttle body, injectors, alternator, and dizzy) and I have a JDM p30 ecu and it’s obd1. (Yes, the JDM P30 will work just fine... you will need an OBD-2A -> OBD-1 adapter harness instead of the 2A -> 2B that I stated above). Will that still still work on my car and motor, or do I have to run a 99si ecu? (No, the '99 Si ECU is not necessary unless you are in some state that has emission inspections).
Second, I thought I needed 99-00si engine harness to use obd2b parts not the obd2a engine harness. (Absolutely NOT... this is a common misconception and a critical error that causes many to have monumental trouble. Stay with the OBD-2A type engine harness from a '96-98 Civic EX).
My last question is because my motor is noe obd2b is there anything else I need to change so that everything is the same OBD? (OBD-1, OBD-2A and OBD-2B parts "function" alike... only the OBD-0 parts are dramatically different. The biggest different between the generations is plug style, so if you get that right, everything will be good).
Old Apr 16, 2020 | 09:35 AM
Ok sweet. So do you know what sensors won’t be used if I do use a p30 ecu?
My last question is do you know what specific sensors or plugs I won’t be using on the automatic wire harness in general?
Old Apr 16, 2020 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Ok sweet. So do you know what sensors won’t be used if I do use a p30 ecu? The only sensor found on an OBD-2 B16A engine that is missing from an OBD-1 B16A engine is the CKF (Crank Fluctuation Sensor) Everything else will be used... although some plugs are different (for example: fuel injectors, IAT, and evap/purge solenoid)
Everything on the transmission portion of the engine harness EXCEPT the VSS, and the reverse lights would need to be wired using a pair of wires that runs into the passenger compartment and terminate at the ECU plugs so that you can extend those to the green crossover plug so that they work.
HondaDude83
Mar 1, 2011 02:52 PM
esco72
Apr 19, 2004 01:47 PM
GirlSolRacer
Mar 25, 2003 11:21 PM
