08 Accord V6 cranks but no start
Son was driving and the engine suddenly shut off. Stopped on the side of the road and towed home. Hasn’t started back up since around 4/10
Thoughts?
Thank you
- The engine will crank but won’t start up.
- ODB reader gives no codes.
- All fuses and relays checks and working properly.
- No noticeable dash blinking lights or messages.
- Car has plenty of gas.
- Lifted back bench and can hear fuel pump cycle when ignition is turned
- No noticeable fuel smell in engine compartment.
- No leaking fuel visible.
Thoughts?
Thank you
Thoughts?
Thank you
Thoughts?
Thank you
Spark issues - pull one and crank the engine, see if there's spark at the plug. Assuming it's a 4cyl, timing chain would be the next guess, worse if it's a v6 with a belt as that one is an interference engine.
good luck.
good luck.
VeroNole08
Nov 13, 2013 06:55 PM
