Assistance needed: B18C fuel trim issue in Neptune
Old Apr 14, 2020 | 06:28 AM
ekcivic2's Avatar
Default Assistance needed: B18C fuel trim issue in Neptune
Hello..Just some information from you guys..i have an issue with my fueling graph from neptune ecu..It generally says that fuel graph should increase or a quite flat graph for the Hi cam vtec.But for me the graph shows a decline till redline..Afr is constant around 12.8 - 13.0. So what could cause this abnormality? Specs b18c gsr with type r cams dual springs, skunk2 IM.stock exhaust header ..piping 2". Thanks.
Old Apr 15, 2020 | 05:54 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default re: Assistance needed: B18C fuel trim issue in Neptune
Your fuel graph will follow your torque curve. Looks like your exhaust is most likely the big restriction in your engine setup.
Nov 18, 2007 09:37 AM
