Honda civic RT 4wd, 1.6, 1988
are you asking about the 5 speed gearbox or rear differential?
i agree gearboxes should use Honda MTF.
google says:
Rear differential lubricant (4WD models)
Above 41-degrees F (5-degrees C)............Hypoid gear oil (API GL5) SAE90
Below 41-degrees F (5-degrees C)............Hypoid gear oil (API GL5) SAE80
https://honda-tech.com/forums/honda-...fluid-1466937/
however, honda has some updated rear diff fluid for RT-AWD diffs like the CR-V i would recommend researching and using over some generic oil.
google says:
r0cket247
Mar 18, 2008 11:10 AM
