I have a 2005 2.4L Accord and generally only do basic DIY stuff. I decided I could handle replacing the gasket in the Vtech solenoid that is causing an oil leak. I was in the process of removing the three 10mm bolts that hold the Vtech solenoid on and I discovered that the connector/sensor below the Vtech soleoid and above the oil filter had snapped off its connection. I might have snapped it while I had my ratchet down there. It looks like the connection itself is broken. It's got a soft rubber boot surrounding some threads. What is this connection? Is it easily fixable?
