Spal 12" fan shroud for a 1/2 size Koyo?
Old Apr 9, 2020 | 08:17 AM
Stopsign32v's Avatar
Loved
Default Spal 12" fan shroud for a 1/2 size Koyo?
Well I'm about to the point of installing my Koyo radiator but I wanted to ask you guys if you know of a shroud that will work on it and utilize a Spal 12" puller fan?
Old Apr 9, 2020 | 10:57 AM
ILOVEYOURHONDA's Avatar
Default Re: Spal 12" fan shroud for a 1/2 size Koyo?
I used a cheap eBay shroud i got off Facebook. The two top bolt locations where the same but i had to cut and re weld the bottom two.
Old Apr 9, 2020 | 11:50 AM
NVturbo's Avatar
O.G. triple O.G.
Those cheap aluminum fan shroud on Ebay will work. That's what I'm using for my SPAL fan as well. In my case, I couldn't find any listings selling just the shroud by itself. Had to contact a seller and they sent me an invoice for the shroud.
Old Apr 9, 2020 | 12:24 PM
DaX's Avatar
DaX
Loved
Community Favorite
Greg / Go-Autoworks makes shrouds for his radiators. He may be able to modify the tab locations to fit the Koyo if it's different.
Old Apr 9, 2020 | 01:29 PM
TheShodan's Avatar
Moderator
Didn't do a shroud. used a 13" SPAL and covered the main areas.
Old Apr 10, 2020 | 06:04 PM
tony_2018's Avatar
Fish Twig
some rubber foam seals would help the corners too.
Old Apr 10, 2020 | 08:02 PM
Loved
How did you mount it? Any pictures?
This one? https://the-fan-man.com/product/13-s...ric-fan-s2044/
Old Apr 10, 2020 | 08:12 PM
NVturbo's Avatar
O.G. triple O.G.
I tried using some with the adhesive backing but they tend to move around and back off. It's fine if you don't have the seals.
Old Apr 11, 2020 | 08:37 AM
thugsbryan's Avatar
What u mean covered the main areas? This is what I'm running, I didnt use a shroud either, but I always wonder if I put a shroud on it if it wud make much of a difference
Old Apr 11, 2020 | 11:47 AM
TheShodan's Avatar
Moderator
I'll try to find some, as I've taken the fan off and sold the radiator.
But to answer your question directly, I used brackets in the shape similar to those used on a turbine housing. The 13" SPAL fan housing acts as a natural shroud on the sides of the Koyo, Mishimoto, and C&R Radiators
SunriseSunset
Apr 15, 2017 04:43 PM
ihavenocar
Sep 16, 2008 10:45 PM
808jdm_profileEG6
Oct 25, 2007 03:34 PM
