IACV small Vs. large opening
Old Apr 8, 2020 | 09:07 AM
evosix's Avatar
Default IACV small Vs. large opening
I have two IACVs, they're both fit my intake manifold but one has a large opening and one has a smaller opening:
Is there a difference between the two?
Thanks!
Old Apr 8, 2020 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: IACV small Vs. large opening
Yes, one has a smaller hole. Heheheh
Seriously, the one with the larger hole will idle slightly higher with a stock ECU in some cases. If you have a tuneable solution, you can adjust the IACV duty cycle up or down to compensate for this.
martyball619
May 24, 2010 01:48 AM
the g2 teg
Mar 22, 2006 04:45 PM
