Will EK coilovers fit my EG ?
Maybe... if the design of the rears is such that the lower fork will fit the EG rear lower arm. Many are designed for either and come with some spacers that are placed on either side of the narrower EK lower arm to fill the gap. The fronts should be just fine.
From my experience all coiovers that I had fit both EG and EK. Only difference was the EKs I had to use the supplied washers for the rears that came with it to bolt onto the LCA.
