Joeyzbg 10.5:1CR B16A2 with 400-420WHP 93 octane possibilities?
Old Apr 6, 2020 | 07:13 AM
Joeyzbg's Avatar
Default Joeyzbg 10.5:1CR B16A2 with 400-420WHP 93 octane possibilities?
Hey guys, what is your opinion about 10.5:1 Compression pistons and a goal of 400-420WHP on RON98 pumpgas (93 in USA)? I can't seem to find any (recent) information on the internet about this.
Car is going to be my daily driver and has to be somewhat reliable.
I know that the compression ratio is pretty high, but i got those pistons for free. Unfortunately there is no E85 available over here.
Specs:
- B16A2 engine
- L.A. Wetsleeves (81.5mm)
- Eagle rods
- CP 10.5:1 pistons (81.5mm)
- Cometic 0.04" (1.016mm) headgasket
- GSR (B18C4) camshafts
- Compcams springs & Retainers
- Spa turbo log manifold (TMH04)
- Maxpeedingrods GT3076 (.82 rear housing)
- 3" exhaust from turbo to muffler
- ARP headstuds
- ACL Main & Rod bearings
- ACT Xtreme pressure plate + 6 puck sprung disk
Fuel:
- Walbro 255lph pump
- Grams 750cc injectors
- Adjustabje fuel pressure regulator
- AEM Water/Meth injection kit
Last edited by Joeyzbg; Apr 8, 2020 at 07:10 AM. Reason: I bought the AEM Water/Meth kit already
Old Apr 6, 2020 | 07:36 AM
NVturbo's Avatar
O.G. triple O.G.
Default re: Joeyzbg 10.5:1CR B16A2 with 400-420WHP 93 octane possibilities?
more like 300hp
that cheap Ebay turbo isn't going to work miracles
Old Apr 6, 2020 | 07:38 AM
ReVtecSi's Avatar
Im not familiar with the manifold but typically the log manifolds are frowned upon for higher HP.
Old Apr 6, 2020 | 07:51 AM
NVturbo's Avatar
O.G. triple O.G.
there are countless manifolds out there that are better. Don't expect much from a cast iron manifold.
Old Apr 6, 2020 | 07:54 AM
Joeyzbg's Avatar
Originally Posted by NVturbo
more like 300hp
Thanks for your response!
The turbo shouldn't be a problem, I ran my stock b18c4 with this exact turbo and manifold. Made 270whp at 10PSI boost and really conservative ignition timing (15*)
Old Apr 6, 2020 | 07:59 AM
Joeyzbg's Avatar
The SPA cast manifolds are known for a good flow and wastegate placement. At least one of the best cast manifolds available.
Old Apr 6, 2020 | 09:16 AM
TheShodan's Avatar
Moderator
Default Re: Joeyzbg 10.5:1CR B16A2 with 400-420WHP 93 octane possibilities?
You could, with that manifold. It doesn't mean you should. I don't think what you're asking for is realistic with that turbocharger and the boost pressures needed to get that power on 93 Octane.
Everything else looks ok to roll except for the manifold and turbocharger combination
Old Apr 6, 2020 | 11:23 AM
Chance EG's Avatar
They're good cast iron manifolds. I think the European crowd uses them pretty often.
Agreed with Shodan however that you're making this much harder on yourself with your choice of turbo & manifold. With that current combination I don't think you'll be able to reach your goals.
10.5:1 CR I'd say is actually a more or less ideal compression ratio for a turbo street 93 octane build.
Old Apr 6, 2020 | 11:40 AM
Joeyzbg's Avatar
Okay guys, thanks for your responses.
Guess i will see what it will do soon on the dyno.
Manifold and turbo upgrade is next on my list. What would you guys recommend for a turbo not too expensive?
I was thinking about maybe a VS racing turbo.
Old Apr 6, 2020 | 02:05 PM
NVturbo's Avatar
O.G. triple O.G.
Originally Posted by Joeyzbg
………….I was thinking about maybe a VS racing turbo.
stop looking at cheap, low-grade stuff. You can get a decent, BNIB Turbonetics for around $525. You GET WHAT YOU PAY FOR....
Old Apr 7, 2020 | 05:05 PM
chonos_'s Avatar
Have you opened that turbo up to check the wheel sizes and verify that they match a real GT3076r? That's something I've noticed that plagues a lot of these eBay turbos... I've never seen someone buy a 57 or 50 trim T3/t04e and actually get one, it's always a 46 trim. Some of the really cheap ($100) GT series fakes seem to have similar issues.
Anyway I run an eBay GT3076r .63a/r on a pretty similar setup, some junk "a/c" cast manifold on a b16 with 11:1 comp and forged rods, water meth (375ml nozzle starting at 4psi, progressive ramp until 20psi), 20psi @ 12 degrees total.
According to virtual dyno it makes just shy of 400hp. I can't really attest to the accuracy of that program, maybe others can chime in?
So yeah I'd check out that turbo to see if it's a faithful reproduction. It's definitely not ball bearing but I don't think that should affect power output much... as long as the geometry is right I don't see why it being a knockoff would limit it to 300hp as someone else said.
Old Apr 7, 2020 | 09:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Why haven't you tested it on a REAL dyno ? What do you have to input into your virtual program for it to provide a HP estimate... and is that at the wheels or the crankshaft ?
Old Apr 7, 2020 | 09:38 PM
chonos_'s Avatar
I don't see the point in testing it, seems like an expensive way to validate something that doesn't really matter to me. VirtualDyno calculates HP based on acceleration logs, it's at the wheels. It's a mid 11 second car, if that helps give you an estimate of power output.
Old Apr 7, 2020 | 10:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There are a TON of variables that affect how wheel HP is calculated by a program like VirtualDyno. My EG hatch was a mid 11 second car with only 297 wheel HP (11.55 @ 118mph)... not that this is comparable to your results, because there are still a plethora of variables between your car and mine that makes the direct comparison incredibly unfair.
I understand that a "Dyno Number" doesn't really matter to you. What should matter is the accuracy of your wideband O2 sensor... comparing your in-car data to a high quality calibrated O2 content device is certainly in your best interest... and the best interest of your engine's long term survival. Just a thought...
Old Apr 8, 2020 | 02:59 AM
NVturbo's Avatar
O.G. triple O.G.
I hope you're being sarcastic but I highly doubt it. I guess you do know more than 99% of us. Of my 25+ years of wrenching on cars, my mind is blown with such idiotic assumptions and idea. Explain to us all how great your Virtual Dyno is.
Old Apr 8, 2020 | 04:36 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
‘the point of a dyno is not about flexing your high numbers , it s more about being able to put a proper load on the motor and getting accurate readings. I’m on wastegate right now and I’m never going to get things tuned just right until I hit the dyno, it’s just not accurate. Once you hit a certain power level street tuning won’t do it anymore, I’m only at 14 psi right now and there is no possible way to street tune at over 30psi. When I get on the dyno I will add a 15% load restriction on the rollers, this will immatate real road conditions like going up a hill and will allow the computer time to log correctly for tuning.
Old Apr 8, 2020 | 08:31 AM
chonos_'s Avatar
Thanks for that, I use the typical Bosch sensor that most widebands use. For low load I listen to a Bosch knock sensor with a headphone amp, otherwise I read plugs. If I'm being honest, maybe I lied. I'd be disappointed if I was making 300whp. The car is about 3000lb with me in it.
My post wasn't intended to be pedantic but I understand tone doesn't carry well over the internet. This is definitely the Honda-Tech warm welcome I've heard about, haha. I don't know how great it is... how accurate is a dyno though? I don't think VD is better, I ran it because I had a mild curiosity... wasn't trying to make a point.
Fair enough. Usually I just go up hills to simulate that... really depends on where you live as to how effective street tuning is. Otherwise I go to the track.
Anyway not trying to derail this thread, was just trying to help the OP.
Old Apr 8, 2020 | 09:32 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
the main reason for a dyno is safety, there is no way in hell I will do a 150mph pull on the street while trying to pay attention to gauges. My street tune is always pretty solid, but limited by speed that becomes a safety factor
Old Apr 8, 2020 | 09:39 AM
chonos_'s Avatar
Oh definitely, even if I was only risking my own safety it's not worth the legal risk. Given that it's just a "fun" car and I don't really race it, I'm happy for now with just a street tune even though I'm probably leaving some power on the table without a proper dyno tune.
Old Apr 8, 2020 | 09:43 AM
Joeyzbg's Avatar
I guess I will see what it makes on the dyno and let you guys know!
Just for my peace of mind I ordered an AEM Water/Meth injection kit.
If everything goes well the engine is done next week, and the dyno will be short after.
Old Apr 8, 2020 | 09:48 AM
chonos_'s Avatar
Good luck! If you want some extra protection I'd recommend wiring in your wideband to your ECU so you can set a fuel cut if the water meth system ever decides to fail.
Also on my car, the water meth seems to like to kill MAP and TPS sensors. You could probably mount it after the throttle body with a spacer and be OK. In my case I put a filter inline with the MAP sensor and haven't solved the TPS issue yet.
Old Apr 8, 2020 | 01:31 PM
GEN2 LS's Avatar
Loved
I have an actual real GT3076R for sale if you're interested! It has an upgraded CHRA from a GTX3076R Gen 1 let me know if you're interested.
atheworld0
Feb 4, 2016 01:13 PM
93egboosted
20
Jun 10, 2008 05:10 AM
ljs88
Jul 15, 2007 01:14 PM
91(si)hatchey
Sep 4, 2006 10:25 PM
JG ENGINE B18C1
Oct 29, 2002 09:06 PM
