Accord 1999 Unable to move on D4 or D3
Hello,
I currently own a accord 99 a few days ago i started to have some issues with it, the car wont move when i place the gearbox on D4 or D3 but does run perfectly on gear '2' and 'R'. When the car is actually cold it will run good on D4 or D3 but after it worms up to its normal tempeture and i turn off and turn back back on the problem starts to occur and i need to change it to '2' to takeoff. Just got it checked on the transmission fluid and its OK.
Any ideas or does someone had the same issue before?
Thanks to all.
Thanks to all.
98-02 are notorious for not setting off the CEL or D4 lamp even if a trouble code has been stored.
Check for any stored codes via the OBDII port.
creeve4
Oct 31, 2016 07:15 AM
