ignition keys won't turn
I have problem with ignition key not turning to start engine on '07 Civic. I tried different keys, lube, and moving steering wheel . Any other options I can do or do I need a new steering lock assembly? If so, anyone know cost? Thanks.
If you can remove the ignition take it to a locksmith and they will replace the lock wafers. Also a must is replacing your worn key. No point in fixing a lock if your keys are worn. $125-$200?
Or get the car to the dealer, they should be able to do both but you have to pay the re-re labor and will add an oe key $400-500
beerski1
Honda Civic (2006 - 2015)
Aug 7, 2019 08:29 AM
maryk2121
Jun 25, 2013 11:35 AM
