Regarding The J35A8 Engine
Old Apr 3, 2020 | 08:25 PM
blacktopper's Avatar
Default Regarding The J35A8 Engine
Haven't been able to find many details on the J35A8 engine. Here are some quick questions:
I believe this engine was used on the 2005 Acura TL (and others as well)?
Fitted to the Acura engine it was offered with only an automatic?
If I use the factory CPU as designed for automatic use will it work with a manual trans as well?
Does this engine use an electric throttle or any other fly-by-wire stuff? If so, I assume it would be possible to replace the stock throttle control with a simple cable set up?
Does this engine use port injection only, or does it include a direct injection nozzle as well?
What direction does this engine rotate?
I would like to swap a 6 spd manual trans in-line style to use for a RWD application just so you know of how it will be used.
Any other engine related stuff I should be thinking of? Anyone know of a good write-up on this engine?
Thanks a bunch!
Randy
Old Oct 9, 2020 | 10:56 PM
AndyD's Avatar
Default Re: Regarding The J35A8 Engine
Randy,
This engine is the 3.5L engine offered in the 2005+ Acura RL and the 2007-2008 Acura TL Type S. The 2007-2008 TL Type S came in both automatic and manual transmissions. The manual transmission was a 6-spd with limited slip diff.
k2GM
Engine Management and Tuning
Nov 9, 2010 04:12 PM
Civic Hybrid
May 15, 2006 09:24 AM
japmobiles.com
May 11, 2005 12:55 AM
GettaluvR
Jun 27, 2002 11:14 AM
