Can i retorque rtv need help fast!!
I've been busy swapping my transmission all day well i get the clutch and fly wheel off i go to do the rearmain seal i didn't realize untill the last second that to replace the housing gaskets you have to remove the pan and the rear main didn't seem to be leaking and i dont want to remove the pan so i retightened the rear main seal housing bolts but im worried that this may cause a leak i never broke the seal i would like some input should i just take the pan off and replace the seals or leave it be the clutch was dry..gotta get to work monday this is my only ride..
96hatchBoy
Jun 11, 2013 03:51 PM
