93 Accord. Can I disable the abs motor? Pump leak.
Old Mar 28, 2020 | 11:27 AM
Manbird12000's Avatar
Icon4 93 Accord. Can I disable the abs motor? Pump leak.
The ABS is trash and I would prefer to disable it due to a slow leak coming from the side of the abs pump manifold/housing (See pic) . So it refills the reservoir from my main master cylinder reservoir. Can I stop it from pulling in fresh brake fluid by pulling the motor circuit breaker?
Last edited by Manbird12000; Mar 28, 2020 at 11:33 AM. Reason: Added picture showing where leak is.
Old Mar 28, 2020 | 02:40 PM
99stockcivic's Avatar
Default Re: 93 Accord. Can I disable the abs motor? Pump leak.
I don't think so, but it's easy enough to test. Simply pull the ABS fuse and see what happens. I think in the end you will have to fix the leak.
try it and report back!
Old Mar 28, 2020 | 04:29 PM
I'll try it. The repair cost is more than the value of the car. Hopefully I can isolate the two systems.
Old Mar 28, 2020 | 06:55 PM
mjs9145's Avatar
I found a place named AUTOTEK in Santa Ana, CA that rebuilds ABS modulators/pumps for about $350. They rebuilt my 1993 Honda Accord ABS modulator and pump 6 months ago and not one problem.
Old Mar 29, 2020 | 10:06 AM
Thankyou for looking that up for me. Unfortunately that would be way out of my price range, plus I'd have to pay someone to install it because I don't have the tools. I'd be happy if I could just disable the thing and shut off it's feed from the master cylinder reservoir.
Old Mar 30, 2020 | 04:36 AM
Fitz Williams's Avatar
10 Year Member
My car is a 94 and may have a different ABS, but I have found that I can pull the fuse in the ABS fuse block with no ill effects. It simply turns off the ABS. It may not be the same for a 93, but it could be worth a try. I turn mine off at certain times to facilitate heavy braking while turning. Probably not a good idea for everyone, but then the LX Accords didn't have ABS to begin with.
Old Mar 30, 2020 | 11:48 AM
This is what i did. I heard the two brake fluids are isolated. So if it continues to leech from the master cylinder reservoir, I might clamp the hose leading into the abs reservoir.
Old Mar 31, 2020 | 05:25 AM
10 Year Member
My ABS reservoir fills from the top through a removable plug. The ABS and the brake reservoir are not connected. The seal below the accumulator was leaking and made a mess of the inner fender. I unplugged the ABS until I could get it fixed. I had no problems with the braking system. Also, I replaced the O-ring without removing the ABS. But I am not familiar with ABS systems prior to the Gen 5 Accord, so yours may be different.
Old Apr 16, 2020 | 04:56 PM
So I pulled the abs motor relay and abs cb's. ABS reservoir is no longer sucking from the master cylinder reservoir. I haven't needed to refil it. Also my brakes actually feel a little firmer.
Old Apr 17, 2020 | 11:20 AM
Hey, alright, not fixed but still "fixed" for now.
bsdubois
Oct 1, 2015 04:16 PM
gucci mane
Jan 4, 2014 03:38 AM
90babyblue
Jan 7, 2005 07:21 AM
