evap purge valve (canister) leaky
Old Mar 27, 2020 | 05:33 PM
whyS0serious's Avatar
Default evap purge valve (canister) leaky
Hi everyone,
Need some inputs on what this substance (clear feels like brake fluid) is on my evap purge canister valve. I just noticed it right now.
Sorry for the big picture. I got it off my phone. If you have any information on this please let me know. Thanks!
Old Mar 28, 2020 | 03:07 PM
Default Re: evap purge valve (canister) leaky
Does this mean it is stuck open? The thing is that it doesn't give a check engine code. But at point its hard to start my car
Old Mar 29, 2020 | 06:45 AM
muellersfan's Avatar
Check for leaking brake and clutch lines near the canister.
Old Mar 29, 2020 | 10:16 AM
Hi muellersfan,
That's the first thing I checked, nothing. I found on youtube that someone had the same problem but the video starter said to look in the service manual. I'll look in my book and see if I find anything.
Old Mar 29, 2020 | 12:23 PM
The service manual doesn't say anything about any oily substance in the evap canister.
Let me know if you had this kind of issue. Also, when I try to start my car it cranks a bit until it starts completely.
Old Mar 29, 2020 | 12:26 PM
What car do you have? Manual or auto?
Old Mar 29, 2020 | 12:51 PM
1999 Civic SI MT
Old Mar 29, 2020 | 01:05 PM
If a buddy presses and holds down the clutch pedal, do you see fluid spraying from a tiny pinhole in the adjacent clutch line?
Losing any fluid from clutch or brake reservoir?
Do you see any accumulation fluid under the leak area (axle, transmission, engine) when you raise the front end and crawl under the car?
Old Mar 29, 2020 | 02:43 PM
I found the culprit. Its my fuel pressure gauge. It has that fluid in gauge so the needle doesn't bounce around. I believe its leaking from there.
Old Mar 29, 2020 | 02:46 PM
Haha...That's a new one. Glad to know it's an easy fix.
Old Mar 29, 2020 | 04:23 PM
right.. haha i never thought it would be that..
thanks for your help Muellersfan
blackcherry
Dec 31, 2013 09:16 AM
CAM0FLAG3
Apr 1, 2009 06:54 PM
pyrojeff
May 15, 2003 04:57 PM
