SRS light reset without dealer??
Old Nov 15, 2002 | 11:05 AM
lufern's Avatar
Default SRS light reset without dealer??
I have a 00'v6 coupe my srs light came off when I installed new gauges. I want to reset it without going to the dealer. Anyone know how, thanks.
Old Nov 15, 2002 | 11:14 AM
jweller's Avatar
Default Re: SRS light reset without dealer?? (a.slowcoupe)
pull fuse 13 on that passenger side fusebox for 10 seconds or more.
Old Nov 15, 2002 | 01:14 PM
lufern's Avatar
thanks man, I'll try it when I get home.
Old Nov 15, 2002 | 01:17 PM
Stew Pidasso's Avatar
Make sure you have your radio code just in case it resets that too.
Old Nov 15, 2002 | 01:57 PM
iam7head's Avatar
Default Re: SRS light reset without dealer?? (Stew Pidasso)
someone taught me how to use a paper clip
to reset SRS light after i remove my seat.
30 seconds for 70 bucks
Old Nov 15, 2002 | 03:33 PM
Chiovnidca's Avatar
Default Re: SRS light reset without dealer?? (jweller)
Are you sure that will clear the codes? I thought you had to screw around with the MES connector to clear SRS codes.
Old Nov 15, 2002 | 04:05 PM
jweller's Avatar
Default Re: SRS light reset without dealer?? (Chiovnidca)
Uhhmmmmm, I thought that reset ALL the codes
hurriedly pages through Helms
edit: you are correct. you have to jumper the MES connector, and go through a series of plug and unplug. It also specifically states to use the SCS connector and NOT a jumper wire. Any particular reason?
[Modified by jweller, 8:12 PM 11/15/2002]
Old Nov 15, 2002 | 04:34 PM
Chiovnidca's Avatar
Yea, the procedure has to be done exactly as the instructions say. With a paper clip, you can't always jump it cleanly, which throws it off. Then you have to start over. I used to take me about 4 tries using a paper clip to get it right. We have the scantool now.
I can't find it , but someone here has a link to the MES procedure. Maybe they will post it, it's too much for me to type.
Old Nov 15, 2002 | 05:42 PM
jweller's Avatar
My good deed for the year, Santy Clause is coming so I'd better be good and kiss *** and maybe he'll bring me a hairdryer to replace my headers
straight outta the helms
Erasing the DTC memory
1)turn ignition switch off
2)connect the scs service connector to the MES connector. Do not use a jumper wire
3)turn igition switch to on
4)The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5)The SRS indicator will come on again. Reconnect the SCS service conector to the MES connectoer within 4 seconds after the light comes on.
6)When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7)The SRS indicator light will blink 2 times indicating that the memory has been errased
8)turn the ignition switch to off and wait for 10 seconds.
I know what your thinking. WTF is the MES connector? good question. maybe someody with a digi-cam can take a pic and post it. its up under the steering wheel. Above and behind the scan tool connector (where you jumper it to get CEL codes)
Old Sep 27, 2003 | 11:44 AM
98LS4dr's Avatar
Will this work for a 96 ACCORD? If not, how would you do it for a 96 ACCORD?
Old Sep 27, 2003 | 02:01 PM
Chiovnidca's Avatar
Default Re: SRS light reset without dealer?? (98LS4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98LS4dr &raquo;</TD></TR><TR><TD CLASS="quote">Will this work for a 96 ACCORD? If not, how would you do it for a 96 ACCORD?</TD></TR></TABLE>
Yes, it's the same.
deanwashere
Jul 25, 2018 04:28 AM
Reaccion
Honda Civic (2006 - 2015)
24
Oct 20, 2017 11:26 AM
lv6l
Honda Civic (2001 - 2005)
Oct 27, 2006 08:13 PM
97RSTEG
Jun 24, 2006 12:10 PM
AcCoRd_HyBrId
May 11, 2002 09:58 PM
