Squeaking noise in the front when turning the wheel
Old Mar 25, 2020 | 06:52 AM
user124's Avatar
Default Squeaking noise in the front when turning the wheel
Its a 98 civic automatic sedan, 1.5 gasoline.
I recently have started hearing a high pitched squeaking noise when turning the wheel (only about half a round either way) AND the same noise occurs when coming to a dead stop and at the beginning of acceleration.
What Ive done so far:
1. Checked the steering fluid - close to full.
2. Checked the springs - Ive heard these break before and they usually sound different.
3. I have a worn out axle joint which needs replacement, but it makes a diffefent sort of clucking sound.
Dont want to take it to a mechanic yet, since Im trying to figure out if I could fix the issue myself.
Any ideas would be welcome.
Thanks!
Old Mar 25, 2020 | 08:44 AM
99stockcivic's Avatar
Default Re: Squeaking noise in the front when turning the wheel
My guess would be a pulley or a loose belt.
Can you have someone look inside the engine bay while turning the wheel to help?
Perhaps a recording might also be help to see and hear.
Old Mar 25, 2020 | 10:17 AM
user124's Avatar
I also noticed that about 5 min after turning the engine off and turning the wheel slightly, it didnt make any noises.
In the video the engine is running and the gear is in park mode and Im slightly turning the wheel.
jayare05
Nov 25, 2012 08:21 AM
michael-crxsi
Mar 30, 2011 04:36 PM
vigorhy
Mar 20, 2008 03:54 PM
es_squared
Jun 24, 2004 01:35 AM
LilDevil
Dec 23, 2001 07:02 AM
