93 Honda Civic DX - Surging Idle
Old Mar 24, 2020 | 07:46 PM
NOminiTRUCKS's Avatar
Default 93 Honda Civic DX - Surging Idle
I am at a loss and figure I should see if anyone else has had this issue. 93 Honda Civic DX. Converted to a 5spd manual. I just replaced the MAP sensor and it didn’t solve anything. If I unplug the MAP sensor vacuum line and plug it the idle slows down and regulates.
Have any of you dealt with this before?
Old Mar 25, 2020 | 06:44 PM
California98Civ's Avatar
Default re: 93 Honda Civic DX - Surging Idle
There have been a couple threads troubleshooting surging idle problems recently. Read through this one and search for the others: https://honda-tech.com/forums/honda-.../#post52087035
Hope that helps...
Old Mar 25, 2020 | 07:03 PM
muellersfan's Avatar
The MAP sensor is bad. Replace it.
Old Mar 26, 2020 | 11:16 AM
I don’t have a vacuum leak from what I can tell. I tested it with starter fluid.
Old Mar 26, 2020 | 11:26 AM
Remove MAP sensor and inspect. Your own test result points to the MAP sensor.
Old Mar 26, 2020 | 06:40 PM
I tested the MAP sensor and all I am getting is 2.26volts. Clearly my MAP sensor is the issue. I’m wondering if the previous owner installed the wrong MAP sensor. Does anyone have a part number for a factory MAP sensor. The local parts store quoted me $280 and $330 for the sensors
Old Mar 26, 2020 | 06:42 PM
Enter your VIN at site below and look up MAP sensor part number.
https://www.bernardiparts.com/
Old Mar 27, 2020 | 11:03 AM
Is there something unique about the DX model? It has a different MAP sensor part number than other models and it is considerably more expensive.
Old Mar 27, 2020 | 11:18 PM
egsleepercivic's Avatar
Is it firewall mounted ?
If so you can use one that was mounted to the throttle body.
I did this on my JDM B16a and have not had any issues, just grab one from the junk yard and try it, just about any obd1 or 2 should work if the plug is the same
KURUPTinc
Mar 13, 2008 08:15 PM
heyitzspikey
Jan 29, 2007 09:19 PM
talley2191
Jan 31, 2006 07:13 PM
Ryanwb
Mar 31, 2003 03:41 PM
civicracer1993
Feb 24, 2003 07:25 PM
