Cylinder 1 and 2 have moisture 99 civic
Old Mar 22, 2020 | 06:08 PM
Carlos Moore's Avatar
Default Cylinder 1 and 2 have moisture 99 civic
I recently bought a $350 civic with a blown motor. Just got a replacement from a salvage yard inspected it today. Pulled cylinders 1 and 2 spark plugs out and the both seem to have a little moisture on both plugs. While the other 2 cylinders are bone dry could the gasket have failed in those 2 holes.
Old Mar 23, 2020 | 07:01 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Cylinder 1 and 2 have moisture 99 civic
It's a salvage yard motor, it could be in any condition, including worse than your current motor. You will have to run through a bunch of tests and inspect several things to know.
Old Mar 23, 2020 | 08:04 AM
The original motor had 2 holes on the block indicating that it was probably run with no oil the exterior look good just those 2 cylinder I'm worried about. I took the valve cover off and looks good as well no oil mixing with water I really won't know until I pull the head. I've heard the head can blow without it mixing with the oil or no white smoke. It not currently installed in the car yet want to change everything while its out the car
Old Mar 23, 2020 | 09:33 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You can attach a transmission and starter to do a compression test.
Or you can do a leak down test on it without a transmission.
These tests can give you some insight.
The leak down is most informative I believe.
Old Mar 26, 2020 | 04:31 PM
I wanna video on YouTube and the leak down test. The video had a civic like mines with a blown gasket and he said if you hear hissing noise when turning the crank then that probably a blown gasket probably gonna take the head to the shop to get it resurfaced amd check for cracks
wheels49
Honda Civic (2001 - 2005)
Mar 3, 2013 02:21 PM
NGATRON45
Sep 4, 2011 02:28 PM
eternalist
Jun 11, 2011 01:36 PM
lsvtek
Mar 23, 2011 05:34 AM
slimbo
Aug 1, 2002 08:51 PM
