Bad ECU?
The car has sat for about 3 years with no battery. It ran before, now it won't start. I've traced it down to the ECU not grounding the main relay to kick on the fuel pump. Before I tear this thing apart, is it possible that the ecu memory was wiped from no power for so long? It's a chipped P28 on Chrome.
I will, but I checked it with a multimeter and got less than 1ohm.
Correct my if I'm wrong, that's the group of 3-4 wires that's bolted to the thermostat housing via what looks to be a double ended terminal end?
Power capacitors can fail even when the ECU is not being used or has power applied to it... just like batteries in a flash light. You can leave it in a drawer for years, and when you need it, it doesn't work. So you remove the end cap and remove the batteries only to find greenish-white chalk and swollen battery case bodies.
Try another known-good ECU and see if everything is alright.
It is unlikely that the EEProm chip would fail. If it is a really early style and has an UV window on top and is exposed and not taped over... maybe it could be blanked. You could certainly try to use it in another socketed P28 and cross your fingers.
trunkluv
Engine Management and Tuning
17
May 30, 2010 08:02 AM
