Racegas fuel concentrate
Old Mar 19, 2020 | 08:34 PM
purposebuilt's Avatar
Default Racegas fuel concentrate
Hi I have a hi compression gsr 12.3:1 so I need to run 100oct or better. So has any one every ran race gas concentrate. Does it cause any detonation or anything and I was wounder if the racegas concentrate can be poured directly in the tank after filling up or do you need to mix it in a gas can first then pore it in
Old Mar 20, 2020 | 03:50 AM
TheShodan's Avatar
Moderator
Default Re: Racegas fuel concentrate
Good stuff, actually. you mix out with your fuel based upon a ratio (pre- calculated on a chart given). best to use 6 gallon cans to mix in as opposed ti pouring directly into the fuel tank
Old Mar 20, 2020 | 11:15 AM
Oh cool thanks alot. I saw it on jegs.com but it says it only raises 4oct points is that true or can it make 100oct
Old Mar 22, 2020 | 09:02 AM
TheShodan's Avatar
Moderator
4 points from the highest pump fuel you're using. if you want higher, you might need to contact VP fuels
Old Mar 24, 2020 | 12:51 PM
Boozt's Avatar
Can't run E85 intstead??
Old Mar 24, 2020 | 07:36 PM
TheShodan's Avatar
Moderator
Bah. inconsistent unless using a flex fuel sensor. I never use the stuff.
Old Mar 24, 2020 | 07:59 PM
HiProfile's Avatar
Not really a big deal since 50% ethanol gives 90% of the air-charge cooling that 98% ethanol does. It also enriches with a lower % mixture, so a lower ethanol mix somewhat fixes itself.
If you look at the tests Evo guys have posted, they get zero knock on their high-boost E85 tunes when they switch to E70.
Old Mar 27, 2020 | 04:38 PM
TheShodan's Avatar
Moderator
Did that years ago (Former Evolution Owner). Still glad I don't use it. BTUs are too low.
allhonda
Sep 25, 2006 04:17 PM
99hondacura
Jul 30, 2006 03:09 AM
Gilbert_619
Jan 25, 2005 04:11 AM
unknown2
Nov 6, 2004 04:14 AM
88CRXHybrid
May 28, 2002 07:22 PM
