Decode fuse box on driver side compartment
Old Mar 19, 2020 | 02:00 PM
zreenmkr's Avatar
Default Decode fuse box on driver side compartment
Anyone knows what each slot is for which labeled here in picture as 5,1 & 2,3.
Need answer asap, thanks. gen 5th also share similar fusebox hxxps://www.autogenius.info/honda-prelude-1997-2001-fuse-box-diagram/
nothing came up when googled: 1992-96 honda prelude passenger compartment fuse box
Old Mar 21, 2020 | 10:42 PM
Aradin's Avatar
Premium Member
Default Re: Decode fuse box on driver side compartment
They are for wiring in additional accessories. They are not all the same and are live at different times depending on the position of the ignition switch. If you intend to use them to add an accessory, use a test light or multimeter to confirm their suitability for the accessory power requirements.
Garebears
Mar 3, 2015 06:10 PM
sramdon
Dec 19, 2013 04:49 PM
DSRxSALSA
Oct 24, 2008 12:47 PM
EliteRacer05
Aug 5, 2005 10:01 AM
