Help with B20 Power Steering
Old Mar 12, 2020 | 11:18 AM
OniChidori's Avatar
Default Help with B20 Power Steering
So I'm doing a B20 Swap into a 98' EM1 and I'm trying to keep the same power steering pump(D-Series). The lower bracket fits but the upper bracket is not compatible, I heard a P72 bracket fits right in is this true or is it the other brackets like the P75 or PR3?
Old Mar 12, 2020 | 08:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help with B20 Power Steering
Where are you located ?
Old Mar 14, 2020 | 11:23 PM
egsleepercivic's Avatar
Believe you will need to switch to b series
Here is my B20 in my 95 integra LS
I swapped the bracket and pump from the original B18b
The bracket is stamped P54
You need to figure out which B series PS pump is compatible with your stock high pressure ps line
95 LS pump and bracket on JDM b20b in 95 ls
Old Mar 15, 2020 | 08:39 AM
tony_2018's Avatar
Fish Twig
Use the honda crv bracket, me thinks, if you want to keep the d-series pump.
Old Mar 15, 2020 | 11:18 AM
Freedo_Civegra's Avatar
I swapped the old pump from my Civic onto the B20 from the CRV when I did that swap. It went on the CRV bracket just fine. Looking at Rockauto, 2000 CRV and 2000 D-series Civic use the same pump.
Old Mar 15, 2020 | 01:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you intend to use the Civic P/S pump, the CRV bracket is the best and most available choice. You could find LS upper and lower P/S brackets, but then you would have to source a "B" series P/S pump that matches your high pressure P/S hard line in your Civic.
Old Mar 16, 2020 | 10:58 AM
416Gang's Avatar
What Freedo said is correct, obtain a b18 or b20 power steering bracket, basically a bracket for non-vtec motors and use your current D series power steering pump, as it will work.
Old Mar 16, 2020 | 02:03 PM
spAdam's Avatar
Loved
Community Favorite
x7. Just went back to a stock Civic pump on mine with the help of the CRV bracket.
Old Mar 16, 2020 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
B18 and B20 P/S brackets are NOT the same. Only the CRV bracket works with the "D" series P/S pump.
Old Mar 16, 2020 | 10:12 PM
tony_2018's Avatar
Fish Twig
*yawn*
Old Mar 17, 2020 | 08:42 AM
That's right. He kinda put words in my mouth. I didn't say a b18 bracket would work. The crv bracket is the only b series ps bracket to my knowledge that works with the d-series pump.
Honda_Fanatic
Nov 23, 2007 11:05 AM
Ge-money
Oct 9, 2006 11:01 AM
