Engine Noise Diagnosis (video included)
Old Mar 12, 2020 | 09:01 AM
lawrencecivic's Avatar
Default Engine Noise Diagnosis (video included)
Hi everyone!
I have an 01 base AT with 130K miles on it. I'm having this engine noise that sounds like something is rattling inside the engine. It's mainly coming from the timing belt side of the bay. This noise is intermittent and mainly comes on during stop and go traffic and then will go off again periodically. The noise becomes louder at around 2000 to 2500 rpm. I am the second owner of the car and looking through the service history the valves have not been adjusted. Any advice would be appreciated. Thank you!
Old Mar 12, 2020 | 09:46 AM
TimiK's Avatar
Default Re: Engine Noise Diagnosis (video included)
When is timing job done?
Old Mar 12, 2020 | 11:39 AM
It was done 3 years ago at 102K
Old Mar 25, 2020 | 06:13 PM
Travbraymorr's Avatar
It’s probably tossed the balance belt and now it’s just twerking inside the timing cover. Put your hand on the engine to feel where the noise is coming from. Probably the bottom of the timing cover. You can pull the crank pulley off and remove the bottom cover and see everything
Old Mar 25, 2020 | 06:14 PM
Timing tensioner are also a common fail
MODsjtown
Jan 4, 2005 01:05 PM
Ibuprofen
Jan 10, 2002 03:51 AM
