Product Inquiry: Blox p2 camshaft valve lash & cam gear settings for B-series engine?
Old Mar 12, 2020 | 06:16 AM
purposebuilt's Avatar
Default Blox p2 valve lash and cam gear setting
Hi I bought a pair of used blox p2 cams and was woundering if any one know the recommended valve lash and cam gear setting
Old Mar 18, 2020 | 01:33 AM
Default Blox p2 cams valve lass and cam gear setting
Your telling me theres no one out there running blox p2 cams
Old Mar 18, 2020 | 10:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Product Inquiry: Blox p2 camshaft valve lash & cam gear settings for B-series eng
Typically, the stock intake lash and .001" loose from the stock exhaust lash values are ideal for moderate aftermarket cams. There are MANY different versions of Blox P2 cams, so I suggest you contact Blox and provide them with the markings requested to identify them and they can provide the cam degree specs.
Old Mar 19, 2020 | 09:42 PM
JKaze's Avatar
10 Year Member
There isn't such thing like "recommended cam gear settings". Check clearances and other
self-claritys, degree them to the manufacturers specs and finetune on dyno or track. Or just check clearances and throw them in and tune up, this way just consuming little bit more time in finetune phase.
Old Mar 20, 2020 | 11:17 AM
Ok cool thanks for the time to reply
SoHc94
Jun 14, 2011 11:22 AM
threehonda
K Series
Dec 20, 2009 06:37 PM
eg:R
Dec 16, 2009 04:22 PM
