Starter ? New Ground ? 911
Well, all the dashboard lights light up but the car won’t turn over just one click
I change the negative wire and put in a four gauge and grounded it
go to start the car all the gauges light up turn the key I just have one click.
is it a starter is it a fuse please help thank you?!
Was this car running before?
take a set of jumper cables and connect BOTH the red and black to the NEG side ONLY.
Connect the other ends to
solid metal on the transmission or right on the starter housing
bare metal on the chassis (even the nuts for the shows should work)
That's could be the brake fluid level.
There is a low fluid level you get the dash light warning. As your pads wear low, the fluid level leaves the reservoir and is contained in the calipers.
When they get really low, (or if you get a leak in a line) the light comes on. You shouldn't add/top off brake fluid as routine maintenance or this warning won't work.
Could also be the parking brake circuit.
A shorted or a broken switch.
Nathan_volcom
Aug 26, 2012 10:17 AM
B18CivicEH2
May 6, 2009 05:29 PM
tannerLSt
17
Jan 21, 2008 03:18 AM
BIGBLOCKEK
May 1, 2006 06:02 PM
