1995 Accord starts and dies
Old Mar 10, 2020 | 04:47 AM
hondamyheart's Avatar
Default 1995 Accord starts and dies
Hi,
I am trying to find out whats wrong with my brother car. 1998 accord auto stock F23. The car starts and dies after few seconds. The CEL is on and gives Code 3 for map sensor. I replaced the sensor, inspected the wiring and even we ran new wires but still same. I cleaned the TB and iacv. I tried to swap the dizzy and did ecu reset but still acts the same. Any ideas what to check next? The spark plugs are new, fuel injectors recently cleaned.
Old Mar 10, 2020 | 09:33 AM
99stockcivic's Avatar
Default Re: 1995 Accord starts and dies
1 - Have you checked and verified voltages going to the MAP sensor?
2 - Have you checked the ground? Loose ground could be issue. The two I can think of are at front of engine and the ground at the intake manifold.
If you keep your foot on the gas will it stay running?
Old Mar 10, 2020 | 11:06 PM
I did check the voltage. I cleaned the grounds as well.
Old Mar 11, 2020 | 07:54 AM
If you leave the MAP sensor unplugged does it run or behave differently?
Old Mar 13, 2020 | 10:06 PM
same thing. if i unplug the tps it will stay running but like a crap.
Old Mar 14, 2020 | 06:40 AM
So with the MAP unplugged it runs (badly, but runs), but plugged in it dies?
Old Mar 14, 2020 | 11:23 AM
No bro. I meant the tps. If I unplug the tps it will run badly. But for the map sensor if I unplug it, the same thing happens car will immediately die.
Old Mar 14, 2020 | 03:46 PM
OK, I know this might sound silly, but could your TPS and MAP be plugged backwards into the wrong plugs?
Old Mar 15, 2020 | 01:10 AM
Yeah. I did check. I think i will try swap ECU.
Old Mar 15, 2020 | 06:04 PM
FastProH's Avatar
When my car had similar symptoms- oil had gotten through the seal in the distributor. This stalled it. I bought another (distributor) online and lasted 1 yr before a camshaft code came up. I found an engine control module from another distributor (distributor fitment was different because of 5speed). Took my old distributor out, put new oil seal in, put ecm on it and it’s been running fine since (related to that problem).
Jozhua723
Jul 1, 2016 01:05 PM
jw 1
Jun 10, 2013 09:00 PM
cindysi
17
Jun 3, 2012 03:12 PM
slob20ef
Jun 20, 2011 12:51 PM
Hung_Lo
May 6, 2006 01:05 AM
