91 prelude si vss
Old Mar 9, 2020 | 08:02 AM
Paul Eckenroad's Avatar
Default 91 prelude si vss
So i have a 91 prelude si b21a1 with auto tranny, i keep having the issue of my speedometer not working, i counted the flashes on the tcm and its sayin vss issue, i know its on the tranny below the distrbuiter underneith like 3 hoses and right beside the tranny mount at least im pretty sure that thats it, question is is there just 1 bolt holding the whole thing in the tranny? Im tryin to take the whole thing out so i can make sure it all works before i start replacing peices of it
Old Mar 11, 2020 | 08:35 PM
motoxxxman's Avatar
Default Re: 91 prelude si vss
Yes, only one bolt holding the VSS in the trans. It's an odd bolt, where the 10mm head sticks up quite a bit above the actual mating surface. You'll need to remove the shift cables and shift cable bracket in order to remove it.
Old Mar 11, 2020 | 08:36 PM
motoxxxman's Avatar
clean car by the way. looks good. aside from the bumper scuff of course lol
Old Mar 12, 2020 | 10:46 AM
1funryd's Avatar
Its because the sensor at the top usually tends to go bad.
EJcivicJDM7
May 7, 2008 09:55 AM
