New to site and needing a little bit of help.
Hello. I am new here, name is Jeff. I have a 2002 Accord EX V6 3.0 with B7XA, 4spd auto transmission. Needing a little bit of help after a new transmission swap.
Issue #1 : when driving and coming to a stop, at the end of the stop there seems to be what is a noise and grinding felt in the brake pedal along with a light buzzing sound. Also when in park and applying brake pedal there is a clicking sound coming from somewhere near the center console.
Issue #2 : when selecting gear the gear selector seems to be in the correct position, but the indicator is showing different gear (when in d4 it says N, D3 shows D4 etc.....)
Looking for some guidance to getting this resolved as thos is my daily driver. I took it to a shop after purchasing a fully remanned transmission from bestbuytransmission.com with a 5yr 100k warranty
i had it installed at a shop and it has been kind of a nightmare from the beginning. The guy wasnt there to receive the new transmission so i had to go to the shop and pick up, or have to reschedule delivery and face a $200 consignment fee by the trucking company. The guy broke a banjo bolt for one of the trans cooling lines which got replaced...and lastly once he thought he had everything buttoned up and was adding fluid and running it through all the gears he says the left axle popped out while he had it in drive....im assuming he didn't have it fastened to the transmission...i do not know what happened but he said he ultimately had to purchase a new axle to install. He also for some reason wanted to pull the engine in order to do the swap, and left TDC SENSOR 1 UNPLUGGED. And lastly left one of the front engine mount bolts out.
Anyone with ideas how to fix the 2 issues i mentioned above or where to start looking to correct, i would definitely appreciate some help as i am starting to become skeptical of letting this place touch my car anymore after 5 days to do the job and have so much wrong.
thank you in advance
Jeff Swope
Jeffereyswope@gmail.com
Jeff Swope
Jeff Swope
Apr 14, 2020 06:35 AM
Tyler Atwood
Jul 2, 2019 04:40 AM
dara05
Jun 12, 2013 03:33 PM
brintonwhalen
Sep 29, 2008 02:49 PM
