Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Honda Accord AT flush
Old Mar 8, 2020 | 09:03 AM
Jdcs's Avatar
Default 2006 Honda Accord AT flush
Ok, so I’m looking to do a transmission flush on my Honda Accord with the V6 and I was just wondering a couple things and I may sound a little stupid when I ask these so please forgive me for my ignorance.
1. How much fluid does an AT on a V6 take because in the owners manual, it has two different measurements, change-3.2 qt and then it says total-7.4. I was just wondering what measurement I should go by for refilling it.
2. I was wondering what other sources there are to buy Honda ATF-Z1 fluid besides a dealership and amazon.
3. If you have any other suggestions or tips for doing an AT flush, it’d be much appreciated.
Old Mar 8, 2020 | 11:46 AM
04compg's Avatar
Default Re: 2006 Honda Accord AT flush
remove drain plug and you’ll get about 3 quarts out, I drain mine into a pan with measurement marks, I use valvoline max life and it shifts better than it did when it was new, change it, drive it around the block and repeat twice
Old Mar 8, 2020 | 01:25 PM
Scottwax's Avatar
Honda doesn't even sell Z-1 ATF anymore, finally realized its garbage. Too many shift modifiers for smooth shifts wear out the transmissions. Their new DW-1 ATF is significantly better. Redline D4 also works very well. Huge thread on transmission fluid for Honda automatics on Acurazine in the 3rd gen TL forum if you have a few hours to read through the threads.
You'll need 3 quarts for a drain and fill.
lauramen
Honda Accord (2013 - 2015)
Aug 18, 2017 02:37 PM
wealth20xx
May 3, 2017 01:36 AM
licks
May 9, 2010 04:24 PM
speedracer28
Jan 23, 2010 11:23 PM
