B16 it cranks but wont start
Old Mar 5, 2020 | 11:13 AM
gian_ed7b16a1's Avatar
Default B16 it cranks but wont start
Hi guys maybe you can help me out with this problem. My car was running good but i noticed that there was a small oil leak from the dizzy i i opened to change the oil seal and when i assembled eveything back together and went to start it back fired very loud and wont start i i changed the plugs checked for spark changed the module and regulator new battery but still wont start can someone tell me what could be the problem its a b16a1 on an ed7. Thanks in advance
Old Mar 5, 2020 | 11:42 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: B16 it cranks but wont start
Did the distributor get installed correctly? 180 out? Plugs and wires in the correct spots?
Old Mar 6, 2020 | 11:26 AM
Yes i put everything back how it was. This problem came after i changed the oil seal i know it's weird but that what happened
Old Mar 6, 2020 | 03:46 PM
4drEF's Avatar
Keyboard Humorist
check your connectors and see if any pins pushed out?
Old Mar 7, 2020 | 05:35 AM
muellersfan's Avatar
When reassembling the distributor housing, it would be quite easy to re-install the distributor coupling 180-degrees out of phase, if you did not note its original position.
See 3:35 - 3:45 at video below.
Old Mar 7, 2020 | 06:40 AM
I tried it both ways just to make sure but still wont start do t know what happened it is making me mad
Old Mar 7, 2020 | 06:56 AM
Verify that the coupling is currently installed in the correct orientation by setting the mechanical timing at TDC1 and checking whether the distributor rotor points at plug wire #1 in the distributor cap.
Old Mar 7, 2020 | 07:32 AM
Evo9GSR's Avatar
loud backfire often means but isnt restricted to bad timing. check the wires and the part of the dizzy that meets the cam to ensure its not backwards. I would check out the rotor and cap just to be safe as well.
ef9_pr0jekt
Mar 7, 2020 07:44 AM
1baddturbosi
Jul 24, 2007 06:52 PM
RJH6
Honda Motorcycles
14
Mar 19, 2005 01:49 PM
b18c1eg2
Aug 21, 2004 12:28 AM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
